Hey guys I am running into a little problem with my rebuild process. I am getting caught up in an area where I have pretty much zero experience so sorry if I have a lot of novice questions on this one.
I pulled a 327 from a family friend's old truck a while back. The motor sat with my uncle for awhile as he worked on getting it ready to run. Through his work he noticed that he had gas leaking in to the oil. He just attributed this to the old carb, however, and we went and got a comepletely rebuilt one like we had been planning on doing in the first place. The new one is a rebuilt rochester q-jet.
We also bought a new edelbrock intake manifold to go with it. We hooked up the two and tried to get it running with no success. After awhile of messing with it we finally got it to run again (the timing seemed to have gotten brutally messed up at some point), although it struggled to idle correctly. Even with adjusting the idle screw and timing it still seemed to just want to die after running for a little bit.
From what I have read this points directly to a stuck float. But, I highly doubt that since we bought the carb rebuilt and it didnt sit any longer than a month, and I am also reluctant to open up the carb and begin tinkering with it myself since I lack any knowledge in this area. Is there any other possibilites that I can check first? I want to fix this myself rather than sending it to a mechanic and never learning how to do it.
Thanks for the help guys, I am learning as I go!
Mac
Mac
