Can a slow blow fuse be used in place of a fusible link? I have always wondered why the factory uses fusible links - I assume they are cheaper.But harder to check & replace.
In my main power supply (NOT starter cable) from the battery to the horn relay, I was planning to use a fuse - 30 or 40 amp.
Pros / cons ?
Gotta have a Chevy !In Durham N.C.
Make it look the way you like it, forget what the other guys say!
Pros / cons ?
