My question is this: Can I have an effective fusible link from Positive battery cable to junction block, WITHOUT replacing the positive cable?? Just finished hooking up my new forward lamp harness in my '68 (Thanks Jimk,& John for voltage regulator plug help)!, and discovered car has no junction block, but the way previous owner had it wired up everything was working! I can go into detail of how it was wired if needed.
Can I order a junction block, mount it to radiator support, connect red 10 gauge wire from harness to it, then run 14 gauge wire from positive cable post down to the junction block? Will it be effective? As a fusible link? The reason I'm asking is it looks like it would be a bear to get to where positive cable hooks onto solenoid to replace the cable. 396, with factory air, and headers.
I'm more interested in functionability, and safety, then originality. Please advise! New to all this- Al
