I'm just now putting my '68 back together and realized that all of the lettering on the fuse panel is unreadable....anyone have a photo or layout diagram ( or know where to get one) so i can figure out what each individual fuse receptical services and what amp # to install?
Thanks!
Left side, top to bottom--1-Clock,lighter,courtesy lights SFE20 2-Taillights SFE20 3-Stop & hazard lights SFE20 4-(little fuse)Instrument lights AGA5
Right side, top to bottom 1-Wiper SFE20 2-Heater/A/C fan AGC25 3-Radio AGC10 4-Dir signals,back up SFE20 5-Gauges AGC10
It would benefit you to spend the money to buy the assembly manual and chassis service manual for your car.
BL
Thank you! I have the assy maunal....could'ent of done without it so far, looks like i'm going to need the service manual as well. Thanks again!
Paul
Note also that you can fix this problem... with a new fuse panel. Mine was rusted up beyond tolerance so this is what I did. Factory Fit has factory style fuse panels for about $75.
You can infer the fuse locations from the factory wiring diagrams. There is also an electrical booklet that lists the fuse sizes.
