This pic is of a 71 fuse block. To remove the fuse clips, use a small screw driver to bend the tabs that hold the clip, one on each side. The 66 fuse block is different but the clips are the are the same.
This pic is of a 67 bulkhead connector. To remove the wire terminals use a smaller screw driver to bend the tabs, one on each side.
Thanks a lot!! I was trying that earlier but seeing was a problem. Your picture was perfect. I`ll have to make another pic tomorrow at work and try again while their both in the slots. Thanks again
