Ok, Some electrical help
needed.
#1. Where does the fuse block
get the power from? The
battery cable terminal of the
starter?? How big of a wire
should it be?
#2. Can I run a wire<size?>
from the fuse block to the
HEI as long as its only hot
while the key is on??
These questions are probably
common sense to some of you
but, I never switched a
points to HEI before. Geeze,
I never had a car old enough
to have points before
Thanks for any help.
–Joe454–
"67 Malibu"
needed.
should it be?
–Joe454–
"67 Malibu"
