It has been several years since I have had my hands in a Dana full floater, what is the correct lube for the wheel bearings? Do you pack these like a front wheel bearing with grease, or are they lubed by the gear oil in the axle? I have to dig into my new to me RV and I would like to pick up the parts I need before digging in to it.
I haven't found much on the web about Dana rears except how to do the ring and pinion.
Thanks.
They are lubed from/with the rear end lube, make sure you put some lube in the hub when you reinstall them to give them some lube til the rear end lube makes it over there. Make sure the diff is full of lube too. Did I type the word lube enough? :D
