How do you put on the one piece fuel line from tank to fuel pump? (Which end to start, how to feed)i already have pre-bent lines,having darn time trying to get around rear spring thru frame etc.
[This message has been edited by chevydude (edited 01-20-2002).]
If I had to do it, I would only do it with Braided fuel line....Bending your own steel lines is really A PAIN!
<BLOCKQUOTE>quote:</font><HR>Originally posted by chevydude:
How do you put on the one piece fuel line from tank to fuel pump? (Which end to start, how to feed)i already have pre-bent lines,having darn time trying to get around rear spring thru frame etc.do i need to hopefully not ,cut the line to install .
<HR></BLOCKQUOTE>
it seems as though this is a hard one to answer. when ever i have replaced fuel and break lines the body was off the frame. that made it a piece of cake. the only thing i can tell you is, put the car on a lift if you can have access to one and you may have to stratigicaly bend it temporarly. use a tubing bender or be very carefull making well rounded bends by hand. it will kink on you easy and quickly. if anyone has done this hopefully they will step up.
