I have a few questions all relating to the fuel system on a 70 396 SS. My sending unit stopped working. I’m sure it’s that because when I ground the brown wire the gauge goes to empty. I have 3 problems.
1. My tank seems to build up excessive pressure after I drive it for a while and remove the filler cap there is quite an air discharge. Return line blocked?
2. The filler neck leaks a little around the seem where it meets the tank. What is the best way to seal this? I have an oxy/acetylene set should I just re-solder / re-braze it. Flame around a tank makes me a bit nervous.
3. Are the sending units repairable and is it possible that some of the symptoms are related? The tank was building pressure even when the sending unit was working. ** If this is in the wrong category “wiring - ele.” I apologize
Thanks for any advise,
Darren
Darren
