Recently completed a new sbc 383 engine build. The builder recommends 1/2" fuel lines. My carburetor calls for 6 psi. What size fuel lines are fuel pump psi ratings based on? I know a bigger line will decrease the pressure, so I need to find one rated for 6 psi on a 1/2" line.
I doubt you need the 1/2 inch line. Likely you will do what the builder says but lots of guys run engines much large than that 383 on 3/8 lines with no sues.
A larger line won't decrease the pressure. Decreased pressure is caused by smaller lines. Fuel pump psi ratings are based on flow, as in 150 gpm @ 6 psi. What type of pump are you considering and where are you going to place it?
The fuel damand of most 383 can be supplied with any on block pump or any 110 gph electric with 3/8 line.
My 383 (465hp) runs VERY well with a 3/8" line from the tank to a Carter 120 gph @ 6psi block mounted pump, 6AN to Holley regulator and 6AN to a PRC adjustable fuel log at the 750 Holley. Pressure set at 6 lbs. :thumbsup:
Discussion Starter #7
Thank you everyone. Spoke with the builder and it was a misunderstanding.
