1 - 8 of 8 Posts
Hey guys, I've been doing my homework on fuel pressure gauges because I'm having a problem with pressure dropping once the motor warms up.
I have narrowed it down to the liquid filled gauge. Just to be safe though, can I trust the gauge when I set the pressure to 6.5 lbs cold? Then I just dont trust it when it drop to 2-3 lbs warm?
I have had the same issue. Test it by pinching the rubber seal on the gauge and see if the pressure changes back to where it was initially set.
The way I solved it was by emptying some of the glycerin from the gauge. It is slightly more than 1/2 of the dial and it works perfectly now.
:yes: exactly ! Same results here as well.
What is the best way to remove the glycerin ?
Remove the gauge and pull the rubber plug and let it drip out onto a rag. If you rip the plug dont worry just clean it up with thinner and put a dab of "the right stuff" over the hole and never worry about it again
1 - 8 of 8 Posts
