I have a '72 Chevelle with a 350cid engine. It's been sitting for 6 years with new oil and an additive that was supposed to help the oil climb the walls and keep things lubed up. I also have been starting it and moving it forward and back through the gears a couple of times a month. The oil is still clean, but I've been told that it breaks down over time and needs to be changed out.
I'm going to do an oil change and will be driving it quite a bit this summer. I'm wondering what suggestions you guys might have for additives for the engine, tranny, and for the fuel tank. I'm just thinking it might need something ran through it since it's been sitting so long. I burned what old fuel was left and put a new tank of the high octane stuff in. I'm thinking I might need something to clean out the tank, carb, fuel lines, etc. Changing the fuel filter might be a good idea as well.
If anyone has ideas or experience with additives and storing your car, I would appreciate anything you could post as far as some options before I change the oil, etc. I'd like to know what really works and not just what the bottle says, or the guy on the other side of the counter.
Thanks!
Bryce
SLC, UT
Thanks!
Bryce
SLC, UT
