Here is what I have done so far. I've done all the testing with the Ohm meter as described in other responses. I have check for bad grounds and the all test positive. My car is a 1970 Chevelle with gauges all other gauges work fine. Is it possible to hook up a wire from the sending units tan wire directly to the gauge? If so looking from the back of the gauge where would attach it so I can test the gauge. Thanks very much.
Rodger
Rodger
