When the truck is turned on (doesn't have to be running) the fuel gauge works fine and reads accurately, but when I turn the truck off, the gauge needle drops down below empty. The needle can take a few seconds to "warm up" when I turn on the truck, just yesterday the needle was stuck below empty but moved up to register the tank contents when I rapped on the gauge lens.
What's at fault here? What is the fix? This has to be something fairly simple I'm guessing since the gauge works fine when the ignition switch is on. Previously the needle registerd the appropriate tank contents whether the ignition was on or off.
