Hey all.....almost done with the body and ready to set on the frame. I got the new brake lines, but since this is not a true resto, but a resto mod I need info.
The engine is a 427 with an electrical fuel pump setup(block off plate installed). I know I will need new fuel lines, but am unsure as to the size and number. Do I need a return with an electric fuel pump? Would I be better going back to a mechanical fuel pump? Please help...I need to order this stuff so I can get my garage back<G>:beers:
If you are going to run a new line anyways, might as well go with 1/2 inch and have less worries. Needing a return line depends on what pump you have. Some need them, others do not. The manufacture of the pump should know. This goes for having a regulator as well.
