Anyone know for sure what configuration the stock factory pistons are in a 1970 Chevelle L65 350/250hp 2 bbl engine?
Are they a 5-6cc four eyebrow flat top OR a dish style 12cc piston?
What is the factory compression ratio on this year engine? I'm thinking 9.0 to 1...
Need to know before I pull the stock heads...thinking about replacing them with a fresh pair of Vortecs and a GM crate 350/330hp hyd flat tappet cam I have
(Lift: .435” Intake / .460” exhaust; Duration @ .050”: 212 deg. Intake / 222 deg; LSA 112.5) on hand but don't want to bump the CR too high.
Adding the Vortecs and this cam should effectively duplicate the GM 350 HO 330hp engine, I would think.
Flat tops, IIRC. Compression was 9.0 to 1 by virtue of 76 cc heads. 10.25 to 1 had 64 cc heads. 2 barrel engines had 441 heads and 4bbl had 186 heads back then. I ran a 70 Nova in AHRA I/O. .390/.410 lift cam, too. Huh, the things you think you can recall....
Steve O.
10.25 CR...bummer. :(
I'm thinking that's too much for the mild cam I'm using.
Thanks for the info!! :thumbsup:
That 10.25 CR is for zero deck height, and "blueprint" specs. Actual assembly line engines were probably a bit lower (like most '60s GM published CRs).
If you are not cutting the block and you are using 0.039" gaskets, your CR will likely be more like ~9.7:1. That would probably be just fine with the efficient Vortec chambers, and the 112.5 LSA / 109 ICL 350 HO cam. Sounds like a pretty good combo, actually.
L65 definitely had 4-eyebrow pistons, so I would guess they are 5-6 cc like you said. I have a '69 L65 apart in my garage now (441 heads and flat-tops - just like '70).
Yeah, if I use a .039" gasket and assuming a .025" deck height, I calculate a 9.65 CR but my quench (.064") is a little too large for my taste.
Although this isn't a max effort engine project. Main concern is reliability and running cool on 87 octane.
But, only needing 32-34 degrees of total timing with the Vortecs will help...
Y'all are correct...I replaced the valve cover gaskets on this engine today...I believe the first time these covers were ever off!!
The heads are -441 castings.
