I am want to replace the 307 / AC springs currently in my car. I have an aluminum headed big block going with no AC going in. The 307 springs sit pretty low even with an aluminum headed small block so I am pretty sure they will need to be replaced with the big block. I know it is not real popular but I like the front end to set up some.
Since you are clearly doing some drag racing...I really liked the Moroso Trick Drag Springs I had on mine, front and rear.
Are you going to Ocean City this weekend?
No Ocean City for me. The engine is currently out of my car. How did the your front end sit with the trick springs? Also how did it handle?
It sat just about level with an all iron 454. And it handled great, in a straight line! Good for cruising but not carving corners, I also had no sway bars, so it's a bit subjective. They do claim that the springs are not for street use.
