I am replacing the front shocks on my 68 4 door and I need to replace the lower mounting nuts and bolts. I read here that the nut should be a prevailing torque lock nut, but I cannot find anything like that with the "c-clip" that is needed to hold the nut on the lower arm.
I purchased a "repro" set of nuts and bolts and they have the clip and look original, but they are not lock nuts. How do you think I should make this connection secure? Should I use a split or other locking washer? Locktite? Something else?
Thanks!
John W.
Thanks!
John W.
