Am I missing a ground somewhere? With everything switched off, my front marker lights are on very dim. Also, the interior light is dim when the door switch is activated. New motor install, good battery but nothing at the key or horn. Body shop had the front clip off. I have the battery grounded to the frame, the rad support grounded to the frame and the firewall grounded to the engine. What's up with the marker lights on dim? It's a '68, int. reg. alt. Tony.
