I recently took my 65 chevelle convertible for an aliginment and the technician said I had the upper control arms on the wrong sides because the best caster (foward tilt) he could get was -2 degrees. I told him that I was looking for +2 degrees as recommended for today's radial tires and I would take the car home and make the change. Well I started to make the change then decided to do some research only to find that both the upper and lower control arms are on the correct sides. I talked to another mechanic who is into 70 Chevelle restorations and he said my car was definitely out. He said that on occasion the frames fold/bend inward due to the cross member not being strong enough usually related to heavy big block engines. Since the frame is a replacement, actually from an Elky, I have no history on it.
My question - should I wait until the mechanic (not the original one) tells me he still can't get enough caster even with lots of shims on the upper arms or should I just bite the bullet and get a pair of adjustable tubular lower control arms and put them on? If I do that do I also need to replace the uppers with tubular arms? At this time money is an issue.
Anyone out there with some ideas, I certainly would appreciate your help, thanks. Tim
