A good friend of mine has a big block chevy motor in his barn.
We think it is a 396. Here are the #'s we found.
Heads
M-Truck
3933148
GM3T
Block
3955272
PASS
HI-PERF
Carb
Q-Jet
40204FF2039
Thanks for any help!
It is a 1969 396 truck motor. Heads are open chamber 122cc also. Both castings indicate the year 1969 also. I don't think I would build anything performance out of it. I don't think those heads are for HP.
Jim
My 70 Chevelle
Jim-
Thanks for your help. Any idea what HP this motor is?
Is a truck block used on regular pickups, or for more heavy duty commercial use trucks?
Thanks again!
I havent run the numbers, but if it is a 69 396 then it is a fine basis for a performance engine. A 396 out of a truck is the same as a passenger 396. The heads, because they are cast with "truck" will be peanut port oval heads, good for low end torque but not for good use over 4500. Regular oval passenger heads are plentiful and cheap, so dont let that stop you. The only real "truck" engines were the 366 and a truck version of the 427, both of which were tall deck engines and had and extra compression ring. If the price is right grab it and build it.
Dave (NY)
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
72 chevelle
TC member #493
Never forget Earnhardt!
[This message has been edited by drptop70ss (edited 05-28-2001).]
Cortez,
Like Dave says, the block should be a regular 396 block, but those heads were used on 396 and 366 truck engines. The HP rating on them was 265 and they have very large combustion chambers.
JR
My 70 Chevelle
