1 - 16 of 16 Posts
My frame is already at my buddy's body shop so I was going to have them paint it satin black - Eastwood has a paint that is strong, chip resistant etc. - Or should I send it out for powdercoating - I'm not building a show car just a nice weekend driver - any feedback?
I just painted a '66 wagon frame two weekends ago...but I have previously had one ('67 Elky) powdercoated too.
Really, it's your call. A paint job is cheaper and easier to touch up as mentioned.
Cost me $240 for blasting and paint/supplies. Two coats epoxy primer and two coats 60% gloss acrylic enamel.
A full frame powdercoat job will run around $600 from my source. In fact, I just picked up all the bumper brackets from being powdercoated yesterday.
hello, 15 years ago i had my frame sand blasted and then we sprayed it with dp 90 . it has never left the garage. it doesnt have a spec of rust at this point. I thought about painting it, but its the rocks, if it ever sees the road again. the rubberized coating should protect also. your choice. mike
Im going to have my frame bed linered. It will hide the flaws and is very durable.
Ron
for years i painted my frames, would put them between two engine stands and spin them as i painted-the last one i decided to have powder coated, took it up on a wed, picked it up fri morn. $350 he did a double coat, first coat got half baked, then applied second coat-sure was easier than painting
if i was doing one that was pretty pitted, after sand blasting, i prob. would fill and paint
My convertible frame is getting galvanized and painted. Once it's galvanized, I'm going to lay down a coat of epoxy primer, then fill in any pits with some Evercoat Metal Glaze, sand it smooth, and lay some coats of Chassis Black down.
I stand to be corrected here, but I read or thought I read that metal to metal and metal glaze are not compatible with epoxy, I looked up evercoat metal glaze and couldn't find what it was compatible with, anybody know if I'm dreaming or I what read, because I may use it if its okay.
Rob
Rob
Metal Glaze is compatible with epoxy primers. I've been using it on my Charger on very small surface imperfections.
I had my frame, all suspension parts, cross member, inner fenders, and rad support blasted and powdercoated for $560. The thing I liked best is I didnt have to do a thing but drop it off and pick it up. I think you can get paints that work just as well if not better, but sometimes you time is more valuable.
1 - 16 of 16 Posts
