1 - 2 of 2 Posts
I have a SBC in my 67, has run and started fine for several years. Battery is grounded to the bolt that secures the alternator to the block, have a thin guage strap from the firewall to the distributor hold down bolt on the Edelbrock Performer. Again have had no starting problems with this setup. A few days ago I put a ground cable from the engine(the hole used to mount 55-57 SBC mounts) to the front crossmember. Now instead of starting instantaneoulsy (sp) it takes a few turns before it fires. Weird. Can one over ground a beast?
Greg,
I doubt seriously that the extra ground wire had any effect on your starting problem. I don't think it is possible to over ground.
If in doubt disconnect and see if the problem goes away and then see if it reapears after you reconnect it again.
FastSS396Man
Brian
Fastss396, Fastss396,Fastss396,
Fastss396,Fastss396,Fastss396,Fastss396,Fastss396,Fastss396,Fastss396
69' SS396 Chevelle
L78 396/375hp
M-21 Close Ratio
Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl.
1 - 2 of 2 Posts
