Finally found the dang wire but what to do next?This is the wire I ask about before.The wire running off the fire wall tru cable coming from the battery.The wire running along the pass-side going to the juction box leading to the I guess horn relay which splits going into the fuse box.Well, I started by removing a wire at a time while watching the volt meter.1st I did the extra fuse box stayed at 10.8 volts,next I did the cable going to the starter stayed at 10.8 volts and then I thought about this wire and the min I took it off the volts went straight to 12.4 volts,put it back on it went right down to 10.8 and leave it there it will go down slowly to around 10.4.Take it off volts go sraight to 12.4.Talk to me.
