1 - 9 of 9 Posts
I will be ordering a Turbo 400 tranny with full manual valve body and need to decide on a forward or reverse pattern. Can someone please educate me on this subject so I can make my decision and what pattern are you using ?
Thanks again
If you going full manual, you might as well be a reverse shift pattern, too.
Just this past summer I changed over from an auto/manual forward to a full manual/reverse pattern TH400. Didn't think I'd like it at first but after a short education period, it's OK now. Takes a little getting used to on the street...
· Lifetime Founding Member
Reverse pattern eliminates the possibility of accidentally going into to neutral (or worse yet-reverse) when making the 2-3 shift.
With reverse pattern you're moving the shift lever away from the neutral gate when you upshift. Normal pattern you're moving the lever toward the neutral gate. Go just a little too far on the 2-3 shift and you're in neutral (and hope you have a rev limiter). A little farther still and you're in reverse. That's real bad. Rear tires lock up and you lose control at considerable speed.
i have always used the forward pattern, mainly because i didnt want to go thru all the gears to get to neut., personal pref-doesnt the reverse patter free wheel when you get off the gas? i only drove one once, thought it free wheeled, just cant remember
forcd ind said:
-doesnt the reverse pattern free wheel when you get off the gas?
Mine does. Probably a little harder on the brakes since there is no compression braking. Takes getting used to...
i was told for a street driven car, go with the forward man valve body. you are not supposed to downshift a reverse body or they say it can blow up.
there is no intermediate band on a reverse body so there is nothing to slow it down. ken jett knows all about this, i hope he jumps in.
1 - 9 of 9 Posts
