OK....Took the motor out and put it back in. Everything was fine before. When I put it back in and bolted everything up, the flywheel is rubbing the top corner of the Bell Housing in about 2 different spots (on the flywheel) during a complete turn over. My question is, what could have caused or be causing this, and will it simply quit when I run the engine? Keep in mind that I can turn the engine over by hand and that the flywheel does not look warped at all. Please HELP!!!!
