Ummm, on the, stroker engines page, the Canfield 195 exhaust ports flow up to 30ccfm. more than what my Canfields flowed a mere 3 weeks ago. Same head as they show. The intake #'s between .200 and .500 was also higher by around 10ccfm. And the site shows a 2.02 int. valve where mine came with a 2.055. I am looking to get that 30ccfm. on the exhaust from bowl and port work, now.:yes:
Mama always says, "don't believe nothin you hear and only half of what you see." I guess Mama is right again.
Banned
Pro-Filer 210cc with 2.055" Valve Upgrade
Flowed @ 28" on a 4.070" bore fixture, 2.055/1.600 valves. Gasket matched.
ACFM
Lift No. 1 No. 2
0.2000 143.0 96.2
0.3000 204.3 150.1
0.4000 249.7 178.0
0.5000 284.2 198.8
0.6000 299.6 211.0
0.7000 299.6 218.1
0.8000 301.9 221.3
0.9000 301.9 222.9
1.0000 299.6 222.9
Average: 264.9 191.0
Dart 215cc Iron Eagle Platinum Heads on 4.030" Bore Adaptor, As Cast with Dart's Valve Job
.100 65.1 - 62.6
.200 130.8 - 114.1
.300 180.8 - 150.2
.400 214.7 - 169.2
.500 236.6 - 186.6
.600 243.4 - 195.4
.700 244.5 - 201.7
.800 243.4 - 206.2
Camel Hump "291" casting heads
2.02/1.6 valves, flowed on 400 bore adaptor, bowl ported, no intake runner work, no major exhaust runner work other than port smooth and polish, no chamber work, mild gasket match, no pipe on exhaust, flowed at 28"
.100" 60 - 53
.200" 125 - 101
.300" 181 - 138
.400" 216 - 163
.500" 227 - 183
.600" 227 - 190
Dart 227cc Pro 1 CNC'd Heads
2.08"/1.6" valves (Chad posted what he got, His numbers and what he got are hand in hand)
.200" 159 - 115
.300" 208 - 150
.400" 255 - 180
.500" 293 - 209
.600" 300 - 217
.700" 308 - 222
.800" 312 - 230
Here is what Chad got on a set of Dart 227cc Pro 1 CNC'd heads he had on his bench (Speier Racing Heads)
http://www.dartheads.com/dartboard/showthread.php?t=2054
Also have some more but the data is not in front of me
Didnt check all those for accuracy never know what youll find on the net.
I have a flow sheet on my 200 Conquests from when I got them out of the box Ill have to check and compare.
