I AM TRYING TO CONVERT TO FLOOR SHIFT ON MY 69 CHEVELLE AND HAVING TROUBLE WITH WIRING! I ADDED TILT COLUMN. HELP!!!!
Need more info, help with what?
If you installed tilt did you get the correct
ignition switch? They operate in the opposite direction than non tilt.
steve, thank you! the wiring on car does not plug into the column. different ends! gosh even hard to explain! if possible can i get email address to sent you pictures? also having trouble wiring new console! thank you so much!
