Pulled the Q-Jet off the ‘71 to freshen it up. It ran ok, but was jetted kinda rich for the elevation, and the accelerator pump had dried up. Got it all back together with new gaskets, fuel filter, and the like. No hard parts changed with the exception of the jets, but now it’s flooding. Can only assume I’ve missed something in the assembly, but am having a hard time figuring out what.
You can see where the gasket for the top plate is getting saturated with fuel while the car cranks. Checked ,and double checked, the needle and seat and there was no debris present. Just to try it I put the old ones back in. Made no difference.
I thought maybe I’d forgotten the gasket that goes under the seat, but that wasn’t it. Is there maybe a gasket that goes under the screw that holds the check ball in place down in the body?
I’m open to suggestions.
Sent from my iPhone using Tapatalk
