I have a 396 just installed in chevelle. It has a new holley 750 on it. Motor has 1000 miles on it and came out of another chevelle. What are some causes of flames shooting out of carb under hard quick throttle. Timing is set at 4 degrees. thanks.
I am assuming that your timing is 4 degrees initial? I'm surpised the car idles at all.
First set your timing around about 35 total just to get a baseline and then see what the car does.
Based on your other post, I am also assuming that this car hasn't really been driven......usually flames poppin out is a sign that the distributor is in a tooth off.
"Model citizen.....with zero discipline"
Big 'ol Baddass Dave Armstrong "the cattle rustler"
'67 Chevelle 396/Th400/4.10
'95 Firebird Formula LT1(2FST4LOV)
The Burnout
The Launch
The MAN!!!(the guy in the black shirt)
[This message has been edited by Big Block Dave (edited 02-22-2001).]
I had this problem recently. Turned out the I had the firing order wrong. #3 and #5 were swapped.
Good luck.
Tom.
I would also agree with that as a #1 preliminary...
make sure you've got 18436572
That would be one reason to drive around without a hood-cool.
I would check the timing as well-I would think a pump gas 396 ought to be capable of 10-12 initial.
I've had my share of problems with this.
The car idles just fine, and then you touch the gas, and voila, it's time to roast marshmallows? Yep, a crossed wire. Re-check your spark plug wires, and I'll bet you there's one crossed somewhere. Fix it, and motor on!
Nick
Proud owner of a 66 Malibu -
355, four speed, 3.08 pegleg
14.94 @ 93.75 (Needs work, I know)
<A HREF="http://www.public.iastate.edu/~amcarthu" TARGET=_blank>
Andy and Nick's Highway to Hell</A>
