Clint no & dbl no!!!!!!
Guy's,be carefull what your suggesting when it comes to oils & oil additives with proper zddp lvl's for hi perf flat tappet cam breakin & for ongoing post breakin protection too.
1) sheel rotella 15w-40 cj rated oil mfg post 2001 doesn't have enough zddp anymore for safe hi perf flat tappet cam protection anymore,it approx 1050ppm when i had it tested.
2) also,i had comps oil additive tested ,came in very low on zinc ,approx 950ppm zinc for breakin addive but for example gm eos and cranes lube had 5,500-6,000ppm zinc which is needed for breakin in.
There's also lucas new tb zinc breakin lube /cam shiled/etc.
As for oil/brk in oil there's chevrons delo 15w-40 (1300ppm zddp for mild perfcams) or for hotter perf cams there's valvolines vr1 race oil's with 1400ppm zddp,spectro's motor guard hi perf oils with 1,800ppm zddp (summits new hi perf oil for flat tappet cam's with 1,800 zddp appears to be the same oil),pennzoils gt race 25-50 oil with 1800+ppm zddp,rp's breakin oil ,joe gibbs breakin oil with approx 2,800ppm zddp,cen-pe-co race oils with approx 2500ppm zddp or std perf oils with approx 1600ppm zddp,etc.
Scott
