I saw a post on a Hot Rod site about gauges mounted in the firewall.
I've seen hundreds of photos with a fuel pressure gauge hooked in the supply line, then started thinking about what you might need to monitor when doing engine work:
Vacuum
Fuel Pressure
Oil Pressure
Temp
Just sort of curious what thoughts were about mounting a set of gauges in the firewall area (that's backed by the empty fresh air plenum) for use when working on the engine? Might even be able to mount a fuel pressure gauge in a "sealed box" with a remote drain tube for safety?
Vacuum
Fuel Pressure
Oil Pressure
Temp
