Looks like a great tool!I use a tool like this. And a degree wheel. Mark a spot once the movement stops and starts at TDC. Then put it in the middle of the 2 marks on the degree wheel.
Don't set the damper at zero, set it wherever it will idle, then line up #1 in the dist.Tomorrow I will finally be firing up the wife's 71 and she will bump the starter until my finger on #1 pushes out air hard and then I will move the crank with a 5/8th socket to the 0 indicator on my harmonic balancer and drop in the dizzy. After I fire I will use my timing light and set it at 12 degrees static. Unless you are planning on setting up a cam or valve timing why would you need more. What are you trying to accomplish?
Sure I will give that a shot.Don't set the damper at zero, set it wherever it will idle, then line up #1 in the dist.
A word of advice: Do not insert the end of the pencil that has the metallic holder with an eraser in it. I could tell you why that's a bad idea but I really don't want to talk about it.you can use a non sharpened pencil and turn the crank with a ratchet until the pencil stops moving
Let me guess Greg, you erased some horsepowerA word of advice: Do not insert the end of the pencil that has the metallic holder with an eraser in it. I could tell you why that's a bad idea but I really don't want to talk about it.
Greg
Well the new exhaust gave me some trouble and cost me a couple hour today but the timing is set @ 8BTC just needing 8 wires, some antifreeze, radiator, fan and fully charge the battery. Tomorrow should be a charm.Don't set the damper at zero, set it wherever it will idle, then line up #1 in the dist.
Okay. I wasn't going to talk about it but I liked your comment about erasing horsepower.Let me guess Greg, you erased some horsepower![]()
I know the guy that invented that. It was called the Whistle Dic. GAPCO in Indianapolis used to market them .has anyone used one of those tools that you screw into block at number one and it gives a whistle sound when you reach top dead center? see pic below. View attachment 721883
For $8 buy a Moroso piston stop so you dont have tales like Greg's.A word of advice: Do not insert the end of the pencil that has the metallic holder with an eraser in it. I could tell you why that's a bad idea but I really don't want to talk about it.
Greg
