I had a miss... can you find it for me?
on the right track there but not the right answer. Concept is there though.OK..I'll bite.#2 intake pushrod drilled thru the rocker..bound up and held the intake valve off its seat.The cylinder pressure is pumped into the intake and fuel wash on the induction stroke polished the piston top.The #2 primary pipe is too dark for coolant in the cyl IMHO.Do we win anything for the correct answer?lol.![]()
Well...no. Not with an adjustable valve train.alright, so the story is someone did a valve job on the car and when they did it they ground the seat of the valve down way to much, so the valve was sitting up into the head. Therefore when the rocker was tightened the valve was opened. When you loosened the rocker the valve would fully seat into the head and the compression in the cylinder would go up to 125psi.
Make sense?
Only if the the valve train is factory stacked and rockers bolts torqued.Assuming that there is no pushrod pinch/bind occuring...a stud/nut would have the intake valve seated when zeroing the lash prior to preload.Is this a mechanical cam vs hydraulic and what Gen is the BBC?alright, so the story is someone did a valve job on the car and when they did it they ground the seat of the valve down way to much, so the valve was sitting up into the head. Therefore when the rocker was tightened the valve was opened. When you loosened the rocker the valve would fully seat into the head and the compression in the cylinder would go up to 125psi.
Make sense?
At .375" higher than the rest....that is one seriously recessed valve seat/face or the incorrect valve stem length to begin with.Hopefully your 125 psi will improve..once the fuel wash is eliminated.:thumbsup:the vavle is sitting 3/8" higher then the rest of the valves in the head. Then loosening the rocker enough to get compression left the rocker completely loose and only held on with a couple of threads.
I didnt keep spinning the engine just enough to get a little compression and was happy.
=alright, so the story is someone did a valve job on the car and when they did it they ground the seat of the valve down way to much, so the valve was sitting up into the head. Therefore when the rocker was tightened the valve was opened. When you loosened the rocker the valve would fully seat into the head and the compression in the cylinder would go up to 125psi.
Make sense?
