1 - 20 of 23 Posts
It was truly amazing and just as great as I expected it to be, sorry if I sound to happy. It´s been a dream for many years now, BUT nearly impossibe to do around here where I live. I could tell you why but I hate to bore you a with that bs. The most important thing is now I can finally put some times in my signature as well.
And even better, more like a wet dream actually, I now have proof that my left tire definetely got some air under it. Which I really wasn´t expecting with a 3,08 and 2400 converter, it actually stalls at 2800 but still..
My class was no faster than 11,50 so my car is pretty ideal (for now) for that class. But I`d love to get them front tires off the ground properly, so please critique my suspension. Let me know if you wan´t details.
Anyways, first pass ever for me netted a 11,71:
kmt is Kilometer per hour (Yes I now, pretty confusing..)
Here´s the rest of my passes in following order:
Best 60: 1,634
Best 1/8: 7,289
Best: 1/4: 11,54
Best: 1/8 mph: 96
Best: mph: 115,3
Had a lot of fun, and nothing broke. Now... how can I go faster ???????? ;)
Oh, and my gearbox didn´t get any better with slushy 2-3 shifts, have to let go so it can get firmly into gear, quick on and off.
Nice runs Remi!
If you want to run faster maybe more gear? If i remember right you have 3.08?
Marcus
Thanks guys, I`m uploading a video on youtube now, Ready soon. With evidence of the smallest wheelie on earth, but it´s got some air under there so it´s a start. not the best pass - missed a shift but the best 60 foot.
I know about the gears, you´re right Marcus 3,08. I was stupid when I ordered the axle from moser. Should have gone 3,42. But it is pretty nice on the street, I gotta admit.
Thinking maybe a better torque converter with higher stall, got the 2400 holeshot from B/M... You think maybe a 4500 unit would pull the wheels higher and survive with the 3,08´s guys?
The only class in Norway you can run a dedicated street car without car and drag license is this class: 11,50 et class. The 10.00 class is a lot of hassle and about 1000 dollars fee each weekend. My car right now I can go flat out, and nearly run 11,50 pretty consistent once I fix the gearbox and get some more experience, which could make it a great car for this event.. Would love higher wheelies !!
Absolutely. Did some small mods. Removed front sway bar, cut inline6 springs to about 1/2" from bottoming out. Front shock max compression min rebound. Rears on full stiff- wasn't really sure about that one. M/t drag radials 295/55-15 to 14 psi. Didn't feel any wheel spin.
I have seen smaller wheelie's than yours. So go for it give it some nitrous right of the line :thumbsup::thumbsup::thumbsup:
Congratulations on getting it running & to the track Remi :beers:
Discussion Starter · #13 ·
Thanks for the kind words. I love this car, looks really rough, but I can drive it everywhere and only let out some air of the rear tires, and a new fan belt to race it. Pretty low maintenance.
The car has been running great for a year and a half now. With 11,2:1 cr and pump fuel.
How can I get those front wheels higher?
Your ET is pretty much identical to mine! I've got 3.42 in mine though!
Great job!
Damn, and with a 3.08 gear, I gotta get to work:D. Congrats on the runs, and especially not breaking anything:yes:
Discussion Starter · #17 ·
Thanks !
Now i gotta find out how I can go faster, probably best to start a new thread. There´s definetely a few areas that is mandatory to look at.
The fuel sending unit 5/16 - which might explain why I feel it´s holding back at 112mph plus - last half is picking up 18mph only, important at the track, very rare I do a full blast on the streets and since this is a street car I`ve been to lazy to change it.. otherwise the fuel system is up to par with 1/2" fuel line, holley black billet hp150 iirc, regulator. Maybe I´m asking to much from my engine with a 3,08 gear.
Converter- would love a 4500-5000rpm ? converter but drive it like a stock converter on the street, is that what you get with the 800 dollars units ? With 3,08 gears how much would I pick up going to 3,55 approx, in a 3800 car.
I wan´t to go faster and get those wheels up in the air ! Enough bla bla, I`ll have to start a new thread for this.
Sure I`m considering a cam swap as well, from that guy here that makes those 107 lsa cams, with short duration that seems to perform ok. hehe. Trying to find out where I should spend the money to get the most performance out of it.
Check with André at Edge converters not sure but think you dont want much more than 3500 if you drive alot on the street like I know you do, but sure André knows what will work+he has great service and price. With more stall you get more slip and heat so you need a good trans cooler.
Marcus
Discussion Starter · #20 ·
Hi Remi. Nice work...your timeslips look great and your car sounded great going down the track. Cool!!!
Thanks ! :) The performer intake is still running on my 4d btw, prolly got around 20 000miles on it by now.
I`ll look into Edge converters, yes. But still not really sure where I should spend my bucks right now. I have a few items on the list. But since I`m building a model A this winter modifications are somewhat limited, small wallet..
Gears, converter, straub cam, suspension.. Trying to improve but getting away with as little as possibe outlay. I don´t have to run 10`s but a big wheelie and faster 60 foot would be great. Feels like it takes quite a bit more hp at the start. At least it hooks good.
1 - 20 of 23 Posts
