1 - 15 of 15 Posts
I did a seach but can't find the equasion for figuring it out. The piston top is down the bore .750 (3/4"), the bore is 4.155 it took 124cc's to fill the space. how do you figure cylinder volume in cc's for the empty cylinder. bore 4.155x2 .750 depth ??????
Thanks.
http://www.jalopyjournal.com/forum/showthread.php?t=18488
Read post #5 in that thread. Second paragraph says since you know how much it takes to fill with the domed piston, you now need to calculate how much liquid it would take to fill with a flat top piston. The difference is your dome volume.
http://www.ehow.com/how_2040922_calculate-volume-cylinder.html
Following that formula, I come up with 10.17ci, which converts to 166.66cc's. If you subtract your 124cc's, that would leave you 42.6cc's, which doesn't seem right. Something's missing. Unless you have a huge dome on those pistons. :eek:
Rick,
Volume = area x depth
Area = pi x r-squared
r = 1/2 of the diameter
Area = pi x (2.0775 x 2.0775) = 13.559 square inches
Volume = 13.559 x .75 depth = 10.169 cubic inches
Convert cubic inches to cc's = 166.64 cc's
You used 124 cc's of fluid, means your dome volume is 166.64 - 124 = 42.64.
That sounds huge. Are you sure of the measurements? Are the domes as big as your thumb?
Super Moderator
The piston top is down the bore .750 (3/4Thanks.
Rick,
When you say the piston top, do you mean the top of the dome, or the flat part of the piston (like if it did not have a dome) ?
Like Jim said, 42cc sounds like an awful big dome. What part number piston is it ?
Thanks Guys now I can figure DCR for the new cam. yes it's a big dome. I had all the info from when I figured this out when I started running these pistons, but lost it in the computer change. they are old trw 2337 .060. I have 119 cc heads, .012 deck height and 9.47cc head gasket (4.345x.039).
Can't find the dome volume by the piston part number ?
These pistons haven't been made since the 70's and they were only made for a short time. Everyplace I've looked no one has a cataloge that lists them.
Thats what it's all about Darren:thumbsup: Gotta keep up with them hot 454's some of these guys are building. JIM, Vince :waving:
DCR calculator says: 10.37 static and the DCR 7.97 @112ICL and cam advanced 6 degrees 8.36 DCR
You sure they are not 2307?
The 2377 was a flat-top from memory
2307's were listed as 50cc's but were usually somewhat less.
Discussion Starter · #13 ·
Hi Mike,
The story I was told is that TRW started making these piston for .060 396 motors but weren't big sellers because the circle track guys were partial block filling and boring to 427CI.. There was a machine shop that use to do alot of big block modified motors here in the Allentown area(recently sold the business and retired). Ted the machinists has been doing motors since the early 60's. When I gave him the piston to bore my block he said he remembered these form the 60-70's. He said the guy who owned the business probably had quite a few of these sets in storage along with alot of other big block cams and other parts. he said they were 12.5 with 112 or 114cc heads. the second pic has info that was written on the lid when I bought the piston on ebay. this is my spare just incase.
big blocks. ha, gotta keep up with budget built small blocks.
i can vouch for the dome on those pistons. they are HUGE.
cant wait till you get the car squared up right, and doesnt leave you down again, its been a bad past year for the both of us.
aaron
Hi Mike,
Sorry about that Rick,, , misread the number :eek:
I was thinking 454 not 396
Whole different deal
The 2377 was a flat top & the 2307 the big dome 454 pistons
1 - 15 of 15 Posts
