Ok I think I will move it. I do have a heater so I still have to connect my heater hoses.I would've put it in the port right of the thermostat housing.
I run my heater off the passenger side port.Ok I think I will move it. I do have a heater so I still have to connect my heater hoses.
Would you mind posting a pic of your setup? I am building this out of the crate (for the first time) and would love to see it.I run my heater off the passenger side port.
I put my oil fitting at the front most DR's side oil plug hole, just above the oilpan. I takes a bit longer to see the pressure rise from there.My BPE 509 wouldn’t maintain a nice temp without the bypass hose.
Out of curiosity where are you putting your oil pressure gauge? My headers get in the way of every place I can find to put one so I don’t have a oil pressure gauge for now.
Agreed, it's all about personal choice and of course wire protection.Any of those three ports will work fine. The sensor needs to be lower than the thermostat.
You get the chicken dinner. 😃Maybe I'm blind, but that looks like a small block water pump!
