This is the round style. 2 lugs for battery cable, and I and S terminals on the side. Are they grounded out through the body, or through the I or S terminal?
Going to use it to fix my hot start problem.
Just curious, will this handle constant curent, say 50 amps? I know some will round selenoids will and others won't.
Steve
I used one from a Ford Super duty pickup of some kind.
It used the body as a ground. I titied a jumper one from the body mounting screw over to a known good ground.
They can hold some serious current. Just the latching mechanism itself pulls 2Amps. So it may be wise to use a thicker gauge ignition-starter wire if you plan on doing some long term cranking of the starter.
71' 3880# with me. Big Block 402, Merlin oval heads, 10.2:1CR, TH400, 3.73 posi,
1/8th: 8.0 @ 88mph
BEST 60': 1.85 w/street tires.
BEST 1/4: 12.5 with 1.89 sixty foot (street tires)
BEST MPH: 109mph
Picture of me roasting the tires and other guy stuff
Video of me staging (smoke of course)
Mine is frame grounded. I couldn't tell you which application it's from. I just told the parts girl that I needed a Ford solenoid for my Chevy. She said "Headers, huh?" and pulled one from the shelf. I've been loyal to her ever since.
My Web Page (updated 3-19-02)
"America will endure!"
Chad Landry
TC Member #643
ACES Member #04556
'68 El Camino, 357, L31 Vortec heads, 700R4, 3.55 posi.
I am pretty sure the ignition switch wire goes to the S terminal. Just have to play around with the ground.
I was wondering about its continuous duty rating because it could be a good alternative for 2 relays when wireing in the Mark VIII or Windstar fans. I picked mine up for $12 CDN, and there avalible anywhere. Just a thought.
Later
Steve
<BLOCKQUOTE>quote:</font><HR>Originally posted by wanarace:
<HR></BLOCKQUOTE>
Had the same though. I melted a solenoid trying to use it to drive my Mark VIII fan. Bad idea.
1/8th: 8.0 @ 88mph
BEST MPH: 109mph
Yes, they are almost always grounded through the mounting base.
You can get a continuous duty solenoid. Look for something like a winch or RV solenoid.
Chad, I'm sure you're loyal to the parts girl because she picked the soleniod for you
I can't believe BB Mike missed his chance at that
You could use a 30A Bosch style relay to fix your starting problems. It would mount behind the engine on the firewall much nicer than the Ford solenoid would.
Peter
[This message has been edited by Peter F. (edited 04-14-2002).]
Peter F. - Actually that's what I am running right now, and it works fine. But if I use the Solenoid, I am going to mount it right next to the battery, so I will only have a foot of live wire. Just incase something ever happens.
Thanks guys
Later
Steve
