1 - 1 of 1 Posts
hello all not sure if I have correct forum placement..adjust accordingly thanks...I am doing a back half on my current monte project. I will be running 2x4 steel from front of frame all the way to rear as a stiffener/rear frame replacement. Would there be any adverse problems with tying in the inner frame to the exhaust so I can avoid routing problems over the hump. so the inner frame actually becomes part of the exhaust.then exit from the 2x4 past the hump and behind the rear tires..it would mount from 2 1/2 exhaust past the trans then exit from 2x4 past the tires..hopefully you can envision this....thanks with your thoughts.....btw the back-half frame would be 41/2 inches narrower than stock at the axle hump
1 - 1 of 1 Posts
