I'm going to be checking out a friends Chevelle today and he is getting a rediculous amount of white smoke coming out of his breathers. He has the evac system the goes into the headers. It is a...
454, 11:1, Arias Pistons, total seal rings, large solid flat tappet, Victor Jr intake, 850 carb, steel crank, stock rods. He has also run a 200 shot up to a 400 shot of NOS on this motor. It seems to runs fine, and its not missing. I'm not seeing any smoke coming out of the exhaust unless the evac is hooked up. If I pull off the evac tubes, it bellows out of the breather system. It doesn't come and go, it is a constant white smoke. Its less noticable when driving, but as soon as it come to an idle, it turns into a cloud.
Is there a quick fix, or am I looking at cracked/broken rings or a messed up head gasket?
