1 - 9 of 9 Posts
Hi Guys,
I am getting ready to install my new engine. It is a 496. The dyno numbers are 548HP @ 5200RPM and 595 ft/lbs TQ at 3200 RPM (nearly a flat tq curve up from there).
Car is a 67 Chevelle, basically stock with regard to weight.
12 bolt with 3.90 posi, 28.5 " tall rear tires
Tremec TKO 600
The car is not complete, but I thought some of you experienced racers would have a guess about a 1/4 mile ET assuming good traction and light.
Thanks,
Matt
Banned
67 Chevelle assuming 3300-3450lbs
496 w/stick
assuming cool air, good traction, well prep track, etc......
10.6-11.2
:thumbsup: Good luck
Hi Guys,
Tremec TKO 600
Thanks,
Matt
Your location shows Colorado. Might help the guessers if they knew the altitude/DA,, you would be running at.
Was the engine dynoed at high altitude and that is the corrected horsepower? LJ
1 - 9 of 9 Posts
