I acquired a fresh shortblock that I have used in my car, and would like to know if there is a way to estimate cam specs from other information. There were no markings on the end of the cam, which is a flat tappet hydraulic. It idles around 950 rpms with 15 degrees of initial timing and only pulls 8 in/hg at idle. It sounds pretty rowdy and pulls against a 2,200 stall converter to the point where I think I'm going to have to get one with more stall. Its a .030 over 454 with flattops and '68 closed chamber heads, compression is around an actual 10.1. I'm not goint to pull valve covers off a perfectly detailed engine, but wonder if there is a way to ballpark estimate specs based on this info. If I am going to replace the converter, I'd like to get it right on the next try. I was told it was around .540, aint' no way this is true based on other big blocks that I've owned. All advice appreciated.
1970 SS454 LS6 11 second street car
why can't it be .540 lift ?
My friends 69 SS has a Summit 238/248 @.050 cam thats .540 lift and it has a pretty rowdy idle.
For a convertor,a 10" 3000-3200 would be good IMHO
X2. In a previous 468, it had a 238/238 .542 lift cam from Clay Smith, on a 108 lsa, and it had a VERY healthy idle. This was on a 9.7-1 compression motor.
The 3000 stall TSI converter was perfect for it.
I had a .540 lift cam in a 427 a few years back, held 15 in/hg and idled at 700 rpm. I figured the cam wuold seem "smaller" to a bigger engine. I guess duraion and lsa make more difference. Can you get a 3,000 stall converter for lockup 2004R?
