The factory tach in my 70 Chevelle is doing some strange things.It wanders all over the 1-3K range and its very bouncy when I rev it.It fluctuates at around 500-1500 rpms at idle.When I give it gas it takes about 2 or 3 seconds to respond then bounces.The tach does not snap up in rpms like it should.It seems it gets a little better the longer I drive it.Any ideas what the problem can be?Thanks guys
Dean Ciampi
Team Chevelle Gold #52
Aces #3094 MY LS6 CHEVELLE
My 2000 Z28
I had a speedometer (electronic - not mechanical) acting similar to that a while back. It turned out to be a defect in the jewel movement (the point on which the needle rotates). It was under warranty at the time, so the dealer replaced it. Other than that, I would look for an intermittent wire connection.
Bob McCormick
69 Malibu project
The tach in my 70 did the same thing that you are talking about. It is an Auto Meter Auto Guage. I after it started I changed my alt, regulator, all my ignition, plugs, wires, complete dist. (HEI), I also changed the sterio and went over all my wiring, but nothing helped. About 2 months ago I put a MSD kit for the HEI, 6A box, and Blaster 2 coil, made a jumper wire to plug into the 6A and it is good now, works just like the day I put it on... I have no idea how or why but its ok now
*Chris Mellow
*1970 Chevelle Malibu 355/TH350 Pearl Blue, Chrome Ralleys
*"Well all I'm saying is that I want to look back and say that I did it the best I could while stuck in this place, had as much fun as I could when I was stuck in this place, played as hard as I could when I was stuck in this place, dobbed as many chicks as I could when I was stuck in this place!" Don: Dazed and Confused
My old tach did the same thing. The ground (to the steering column) wasn't good enough. I took it out to the firewall and the problem went away. connection was a little iffy also.
71' 3880# with me. Big Block 402, TH400, 3.73 posi,
BEST 1/8th: 8.252 @ 84.56mph (1.855 sixty foot)
Last years previous best 1/4: 13.1sec @ 105 MPH (2.10 sixty foot)
Picture of me roasting the tires and other guy stuff
Video of me staging (smoke of course)
<BLOCKQUOTE>quote:</font><HR>Originally posted by BB_Mike:
<HR></BLOCKQUOTE>
Hmmm I think I am on to something.Thanks Mike
