The easiest is with both balancer and pump off. If you leave the balancer on and you have the short pump, then it doesn't make much difference if the pump is on or off. The balancer is what gets in the way the most. If you are ever going to do your own engine work, invest in TWO tools: a balancer puller and an installer.
Tom Parsons
