The machine shop has given me the following information.
Keith Black Pistons (Flat Top) .030 overForgot to ask compression ration, but pump gas friendly.
4.250 Crank (Total Displacement 489)
454 2-bolt block. 049 heads, Ported, Polished, Bowl Blend, and Increased valve size.
the suggested cam:
234/244 0553/.578 112LSA
Performer RPM Intake.
Melling High Volume Pump, Clevit Bearings.
Proform 1.7 Aluminum Roller Rockers.
Would you suggest a different cam. I have power brakes and want to maintain their use. What kind of power are we looking at, Guesstimates?
Thank You,
Big D
· In Memoriam
what's the cc of the heads now? did whoever did the head work cc the chambers?
Otherwise, the worst thing I see wrong is the old Melling HV/HP oil pump. this is not needed.
The Pump just comes as part of the kit, Don't know what the CC will be, the heads haven't been reworked yet.
I read alot about the VooDoo 268 cam.... should I go with this?
If you take the 049 heads, put larger valves and some mild porting, with the combo I described above what kind of power would I be looking at.
Please read the Sticky about the Melling oil pumps below..
http://www.nastyz28.com/forum/showthread.php?t=65870
That's over on MadMike's SGCOG site!!
pdq67
I'll verify which pump is gonna be in the motor and go from there.
I would still like if someone with a Desktop Dyno to run some estimates to let me know what kind of power I can expect.
Also, anyone have anything to say about the Cam?
