Engine size
571 10
Trying to find out what motor is in this 67 Chevelle. Here are numbers off the motor 105130TB. Have done alot of research and found nothing.
1 - 11 of 11 Posts
Are those casting numbers from behind Drv side head?
there was no two-letter suffix code of TB. there was plenty of three letter codes starting with TB. so, pictures would help
That sure is a BB. A few things the heater hose and temp sender hooks up are switched. Not sure if it really makes a difference. Also get rid of the fire hazard of a rubber fuel hose. Can you post a picture of the stamp pad
Reactions: GM man
1 - 11 of 11 Posts
