I finally took some pics of the engine.
I have come to my senses and will run the cam I have as it is already broke in and is in great condition. The only things that will change is a tighter converter, stud mounted SS roller rockers and studs on the mains. I will replace the guides and check the valves and double check the push rod lengths as this may have been the reason for the guide failure.
Still not sure what was in the oil but here are some pics of the scratches in the cylinder walls. Also some of some painting I did.
Lookes like Daves car
Some pics of the main bearings with scratches
