Have heard many arguments about what proper engine oil to use on older engines. I have a 1972 chevelle SS with a 350, I was told any oil is fine and I was also told the newer oil doenst have the proper ingredeints in it that the older engines need? Does anyone know the truth about this, If so what is the recommended oil and weight?:confused:
BIGSKY,I sent you some oil info that should answer your question/s so check your email.
Scott
