I had one of these inline heaters in my El Camino for several years when I was stationed just outside Anchorage. It doesn't get really, really cold there, as in Fairbanks and interior Alaska. It was inline in one of the heater hoses. Worked fine. Plug it in in the evening and unplug in the morning. Circulates warmed coolant. there are no moving parts, unless you consider a check valve a moving part.I think I have seen a heater that goes inline with a radiator hose. I take it this is a race car that is not supposed to have anti freeze in it ? I am not sure what the antifreeze is that they use to winterize marine engines. Maybe that would work ?
Where are you located and how cold does it get ?
Because it's a race car not a street car.FWIW...you don't have too many choices in a freezing climate if you don't want a "cracked block/head, etc.". Either drain the block thru the drains and blow it out w/compressed air or use the correct antifreeze mix for your area...don't be cheap, a cracked block over the price of a couple of gallons of antifreeze...no comparison. Heated garage...nice.. if you have one and no power outages. My question to you is why are you trying to avoid antifreeze...environment, cylinder leaks, cooling problems or ... ?
Just want to add to Olds' answer because a lot of guys that dont race do not realize that you are not allowed to run antifreeze in an engine at the drag strip. If something breaks antifreeze is worse than oil to get cleaned up off the track.FWIW...you don't have too many choices in a freezing climate if you don't want a "cracked block/head, etc.". Either drain the block thru the drains and blow it out w/compressed air or use the correct antifreeze mix for your area...don't be cheap, a cracked block over the price of a couple of gallons of antifreeze...no comparison. Heated garage...nice.. if you have one and no power outages. My question to you is why are you trying to avoid antifreeze...environment, cylinder leaks, cooling problems or ... ?
