1 - 12 of 12 Posts
Looking for some advice. First time engine disassembly
What are some good techniques for removing freeze plugs?
Second question. The manual says remove the two bolts retaining the cam and just pull it out. Well its not coming out. What do I need or need to do.
What engine are you working on?
Not enough info-- Heads are off, right? pushrods out?
Make sure when you get to the connecting rods that the same caps and bolts go back on them in the same order..
Dale..
1. You will be replacing the freeze plugs, So just bang a screw driver through the center and pry out.
2. I am assuming that you have removed the push rods and lifters. The cam should slide right out But, Since the lobes are oblong shaped, You will need to fineness it out making sure not to hit the cam bearings as you go.
Wasnt trying to give you grief just that you mentioned retaining bolts for camshaft and chevy doesent have them.
Suggest getting the right book to go with your engine. I used "How to Rebuild Your Smallblock Chevy" when I did mine last year. get the Tom Monroe How to Rebuild Your Small Block Ford for yours. Great book.
If this is the first time, I would photo everything prior to removal.
I bag each and every bolt, or group of bolts, and label the bag with a Sharpie or paint marker. Same for small parts. I start this when removing stuff in the car. Use plastic sandwich bags.
Repeat, bag and label everything!
For stuff that has to stay in the same order, such as main and rod caps, punch mark them with numbers or dots to make sure you put them back where they came from, after they are all nice and clean.
For the cam, you must have the lifters out, timing chain, fuel pump and distributor out, and it should pull out the front. Make sure it does not hit the bearings on the way out. A Ford 289 has a cam retainer, held by two bolts. Remove the fuel pum eccentric, the cam gear, and the two bolts and cam retainer plate. Keep the bolts, the heads are shallow so they clear the cam gear!!!!! Make sure you note the orientation of the cam retainer plate, it is meant to go on only one way.
Pay close attention to the oil plugs behind/adjacent the plate, so you get them right upon reassembly.
I usually let the machine shop do the freeze plugs or leave them in, unless you have had cooling or oil system probs. I have redone several engines without touchiing them. 302's to be exact.
But the larger ones can be punched in on one side to turn them, then grabbed and pulled out. The smaller ones, you can drill and put in a screw to remove Others may have better methods for this.
with the dist, lifters, fuel pump and cam retainer plate out of the equation it ought to come out. As already suggested it takes a little maneuvering to extract due to the lobes preferring to beat the **** out of the bushings than to slide easily past. I've seen car cams that were gunked into place and had to pry them a skoshe to start them coming forward.
And there is too a chevy with a cam retainer, 427 tall decks had it and also late model roller blocks.
· Super Moderator
Dale,
Only other advice is .... DO NOT throw any of the old parts away until you are completely finished with the rebuild. Ford used several configurations of timing sprockets especially. Make sure to save them so you can compare them to the new ones.
I'm guessing this block, the heads and crankshft are going to a Machine shop to be cleaned and checked out before you spend a lot of money building the engine....:thumbsup:. They will take care of the freeze plugs, remove the cam and install the new cam bearings that it sounds like you may need..:beers:.
As some of you have stated it should just slide out at this point. All I can figure is a bearing or all of them is/are hanging the shaft up. Right now I have less than an 1/8 of movement. Lobes are not the problem.
Thank all of you for not saying stupid things about asking a Ford question on a Chevelle site. The Chevelle is quite happy having a Mustang friend parked next to her.
1 - 12 of 12 Posts
